Kernel: security and bugfix update
The Linux kernel was updated to fix security issues and bugs.
Security issues fixed:
CVE-2014-3153: The futex_requeue function in kernel/futex.c in the Linux
kernel did not ensure that calls have two different futex addresses,
which allowed local users to gain privileges via a crafted FUTEX_REQUEUE
command that facilitates unsafe waiter modification.
CVE-2014-3144: The (1) BPF_S_ANC_NLATTR and (2) BPF_S_ANC_NLATTR_NEST
extension implementations in the sk_run_filter function in
net/core/filter.c in the Linux kernel did not check whether a certain
length value is sufficiently large, which allowed local users to cause
a denial of service (integer underflow and system crash) via crafted BPF
instructions. NOTE: the affected code was moved to the __skb_get_nlattr
and __skb_get_nlattr_nest functions before the vulnerability was
announced.
CVE-2014-3145: The BPF_S_ANC_NLATTR_NEST extension implementation in
the sk_run_filter function in net/core/filter.c in the Linux kernel
used the reverse order in a certain subtraction, which allowed local
users to cause a denial of service (over-read and system crash) via
crafted BPF instructions. NOTE: the affected code was moved to the
__skb_get_nlattr_nest function before the vulnerability was announced.
CVE-2014-0077: drivers/vhost/net.c in the Linux kernel, when mergeable
buffers are disabled, did not properly validate packet lengths, which
allowed guest OS users to cause a denial of service (memory corruption
and host OS crash) or possibly gain privileges on the host OS via crafted
packets, related to the handle_rx and get_rx_bufs functions.
CVE-2014-0055: The get_rx_bufs function in drivers/vhost/net.c in the
vhost-net subsystem in the Linux kernel package did not properly handle
vhost_get_vq_desc errors, which allowed guest OS users to cause a denial
of service (host OS crash) via unspecified vectors.
CVE-2014-2678: The rds_iw_laddr_check function in net/rds/iw.c in the
Linux kernel allowed local users to cause a denial of service (NULL
pointer dereference and system crash) or possibly have unspecified other
impact via a bind system call for an RDS socket on a system that lacks
RDS transports.
CVE-2013-7339: The rds_ib_laddr_check function in net/rds/ib.c in the
RDS transports.
CVE-2014-2851: Integer overflow in the ping_init_sock function in
net/ipv4/ping.c in the Linux kernel allowed local users to cause a denial
of service (use-after-free and system crash) or possibly gain privileges
via a crafted application that leverages an improperly managed reference
counter.
- ext4: Fix buffer double free in ext4_alloc_branch() (bnc#880599
bnc#876981).
- patches.fixes/firewire-01-net-fix-use-after-free.patch,
patches.fixes/firewire-02-ohci-fix-probe-failure-with-agere-lsi-controllers.patch,
patches.fixes/firewire-03-dont-use-prepare_delayed_work.patch: Add
missing bug reference (bnc#881697).
- firewire: don't use PREPARE_DELAYED_WORK.
- firewire: ohci: fix probe failure with Agere/LSI controllers.
- firewire: net: fix use after free.
- USB: OHCI: fix problem with global suspend on ATI controllers
(bnc#868315).
- mm: revert "page-writeback.c: subtract min_free_kbytes from
dirtyable memory" (bnc#879792).
- usb: musb: tusb6010: Use musb->tusb_revision instead of
tusb_get_revision call (bnc#872715).
- usb: musb: tusb6010: Add tusb_revision to struct musb to store
the revision (bnc#872715).
- ALSA: hda - Fix onboard audio on Intel H97/Z97 chipsets
(bnc#880613).
- floppy: do not corrupt bio.bi_flags when reading block 0
(bnc#879258).
- reiserfs: call truncate_setsize under tailpack mutex
(bnc#878115).
- Update Xen config files: Set compatibility level back to 4.1
(bnc#851338).
- Update config files.
Guillaume GARDET reported a broken build due to CONFIG_USB_SERIAL_GENERIC
being modular
- memcg: deprecate memory.force_empty knob (bnc#878274).
- nfsd: when reusing an existing repcache entry, unhash it first
(bnc#877721).
- Enable Socketcan again for i386 and x86_64 (bnc#858067)
- xhci: extend quirk for Renesas cards (bnc#877713).
- xhci: Fix resume issues on Renesas chips in Samsung laptops
(bnc#877713).
- mm: try_to_unmap_cluster() should lock_page() before mlocking
(bnc#876102, CVE-2014-3122).
- drm/i915, HD-audio: Don't continue probing when nomodeset is
given (bnc#882648).
- x86/mm/numa: Fix 32-bit kernel NUMA boot (bnc#881727).
https://bugzilla.novell.com/show_bug.cgi?id=851338
https://bugzilla.novell.com/show_bug.cgi?id=858067
https://bugzilla.novell.com/show_bug.cgi?id=868315
https://bugzilla.novell.com/show_bug.cgi?id=869563
https://bugzilla.novell.com/show_bug.cgi?id=870173
https://bugzilla.novell.com/show_bug.cgi?id=870576
https://bugzilla.novell.com/show_bug.cgi?id=871561
https://bugzilla.novell.com/show_bug.cgi?id=872715
https://bugzilla.novell.com/show_bug.cgi?id=873374
https://bugzilla.novell.com/show_bug.cgi?id=876102
https://bugzilla.novell.com/show_bug.cgi?id=876981
https://bugzilla.novell.com/show_bug.cgi?id=877713
https://bugzilla.novell.com/show_bug.cgi?id=877721
https://bugzilla.novell.com/show_bug.cgi?id=878115
https://bugzilla.novell.com/show_bug.cgi?id=878274
https://bugzilla.novell.com/show_bug.cgi?id=879258
https://bugzilla.novell.com/show_bug.cgi?id=879792
https://bugzilla.novell.com/show_bug.cgi?id=880599
https://bugzilla.novell.com/show_bug.cgi?id=880613
https://bugzilla.novell.com/show_bug.cgi?id=880892
https://bugzilla.novell.com/show_bug.cgi?id=881697
https://bugzilla.novell.com/show_bug.cgi?id=882648
https://bugzilla.novell.com/show_bug.cgi?id=881727
https://bugzilla.novell.com/show_bug.cgi?id=877257
http://cve.mitre.org/cgi-bin/cvename.cg ... -2014-3145
http://cve.mitre.org/cgi-bin/cvename.cg ... -2014-3144
http://cve.mitre.org/cgi-bin/cvename.cg ... -2014-3122
http://cve.mitre.org/cgi-bin/cvename.cg ... -2014-2678
http://cve.mitre.org/cgi-bin/cvename.cg ... -2014-0077
http://cve.mitre.org/cgi-bin/cvename.cg ... -2014-0055
http://cve.mitre.org/cgi-bin/cvename.cg ... -2014-3153
http://cve.mitre.org/cgi-bin/cvename.cg ... -2014-2851
http://cve.mitre.org/cgi-bin/cvename.cg ... -2013-7339
Ein Neustart des Rechners wird für die Übernahme der Änderungen der Aktualisierung erforderlich.
