Kernel bug- and security-update
openSUSE 12.1 Kernel bug- and security-update
This kernel update of the openSUSE 12.1 kernel brings
various bug and security fixes.
Following issues were fixed:
- tcp: drop SYN+FIN messages (bnc#765102, CVE-2012-2663).
- net: sock: validate data_len before allocating skb in sock_alloc_send_pskb() (bnc#765320, CVE-2012-2136).
- thp: avoid atomic64_read in pmd_read_atomic for 32bit PAE (bnc#762991).
- be2net: non-member vlan pkts not received in promiscous mode (bnc#732006 CVE-2011-3347).
- fcaps: clear the same personality flags as suid when fcaps are used (bnc#758260 CVE-2012-2123).
- macvtap: zerocopy: validate vectors before building skb (bnc#758243 CVE-2012-2119).
- macvtap: zerocopy: set SKBTX_DEV_ZEROCOPY only when skb is built successfully (bnc#758243 CVE-2012-2119).
- macvtap: zerocopy: put page when fail to get all requested user pages (bnc#758243 CVE-2012-2119).
- macvtap: zerocopy: fix offset calculation when building skb (bnc#758243 CVE-2012-2119).
- Avoid reading past buffer when calling GETACL (bnc#762992).
- Avoid beyond bounds copy while caching ACL (bnc#762992).
- Fix length of buffer copied in __nfs4_get_acl_uncached (bnc#762992).
- hfsplus: Fix potential buffer overflows (bnc#760902 CVE-2009-4020).
- usb/net: rndis: merge command codes.
only net/hyperv part
- usb/net: rndis: remove ambigous status codes.
- usb/net: rndis: break out defines.
- net/hyperv: Add flow control based on hi/low watermark.
- hv: fix return type of hv_post_message().
- Drivers: hv: util: Properly handle version negotiations.
- Drivers: hv: Get rid of an unnecessary check in vmbus_prep_negotiate_resp().
- HID: hyperv: Set the hid drvdata correctly.
- HID: hid-hyperv: Do not use hid_parse_report() directly.
- [SCSI] storvsc: Properly handle errors from the host (bnc#747404).
- Delete patches.suse/suse-hv-storvsc-ignore-ata_16.patch.
- patches.suse/suse-hv-pata_piix-ignore-disks.patch
replace our version of this patch with upstream variant:
ata_piix: defer disks to the Hyper-V drivers by default
libata: add a host flag to ignore detected ATA devices.
- mm: pmd_read_atomic: fix 32bit PAE pmd walk vs pmd_populate
SMP race condition (bnc#762991 CVE-2012-2373).
- xfrm: take net hdr len into account for esp payload size
calculation (bnc#759545).
- net/hyperv: Adding cancellation to ensure rndis filter is closed.
- xfs: Fix oops on IO error during xlog_recover_process_iunlinks()
(bnc#761681).
- thp: reduce khugepaged freezing latency (bnc#760860).
- igb: fix rtnl race in PM resume path (bnc#748859).
- ixgbe: add missing rtnl_lock in PM resume path (bnc#748859).
- cdc_ether: Ignore bogus union descriptor for RNDIS devices (bnc#735362).
Taking the fix from net-next
- Fix kABI breakage due to including proc_fs.h in kernel/fork.c
modversion changed because of changes in struct proc_dir_entry (became defined)
Refresh patches.fixes/procfs-namespace-pid_ns-fix-leakage-on-fork-failure.
- Disabled MMC_TEST (bnc#760077).
- Input: ALPS - add semi-MT support for v3 protocol (bnc#716996).
- Input: ALPS - add support for protocol versions 3 and 4 (bnc#716996).
- Input: ALPS - remove assumptions about packet size (bnc#716996).
- Input: ALPS - add protocol version field in alps_model_info (bnc#716996).
- Input: ALPS - move protocol information to Documentation (bnc#716996).
- sysctl/defaults: kernel.hung_task_timeout -> kernel.hung_task_timeout_secs (bnc#700174)
- btrfs: partial revert of truncation improvements (FATE#306586 bnc#748463 bnc#760279).
- libata: skip old error history when counting probe trials.
- procfs, namespace, pid_ns: fix leakage upon fork() failure (bnc#757783).
- cdc-wdm: fix race leading leading to memory corruption (bnc#759554).
This patch fixes a race whereby a pointer to a buffer
would be overwritten while the buffer was in use leading
to a double free and a memory leak. This causes crashes.
This bug was introduced in 2.6.34
- netfront: delay gARP until backend switches to Connected.
- xenbus: Reject replies with payload > XENSTORE_PAYLOAD_MAX.
- xenbus: check availability of XS_RESET_WATCHES command.
- xenbus_dev: add missing error checks to watch handling.
- drivers/xen/: use strlcpy() instead of strncpy().
- blkfront: properly fail packet requests (bnc#745929).
- Linux 3.1.10.
- Update Xen config files.
- Refresh other Xen patches.
- tlan: add cast needed for proper 64 bit operation (bnc#756840).
- dl2k: Tighten ioctl permissions (bnc#758813).
- mqueue: fix a vfsmount longterm reference leak (bnc#757783).
- cciss: Add IRQF_SHARED back in for the non-MSI(X) interrupt
handler (bnc#757789).
- procfs: fix a vfsmount longterm reference leak (bnc#757783).
- uwb: fix error handling (bnc#731720).
This fixes a kernel error on unplugging an uwb dongle
- uwb: fix use of del_timer_sync() in interrupt (bnc#731720).
This fixes a kernel warning on plugging in an uwb dongle
- acer-wmi: Detect communication hot key number.
- acer-wmi: replaced the hard coded bitmap by the communication devices bitmap from SMBIOS.
- acer-wmi: add ACER_WMID_v2 interface flag to represent new notebooks.
- acer-wmi: No wifi rfkill on Sony machines.
- acer-wmi: No wifi rfkill on Lenovo machines.
- [media] cx22702: Fix signal strength.
- fs: cachefiles: Add support for large files in filesystem
caching (bnc#747038).
- Drivers: scsi: storvsc: Account for in-transit packets in the
RESET path.
- CPU hotplug, cpusets, suspend: Don't touch cpusets during suspend/resume (bnc#752460).
- net: fix a potential rcu_read_lock() imbalance in rt6_fill_node() (bnc#754186, bnc#736268).
- This commit fixes suspend to ram breakage reported in bnc#764864.
Remove dud patch. The problem it addressed is being respun upstream,
is in tip, but not yet mainlined. See bnc#752460 for details regarding
the problem the now removed patch fixed while breaking S2R.
Delete patches.fixes/cpusets-Dont-touch-cpusets-during-suspend-or-resume.patch.
- Remove dud patch. The problem it addressed is being respun upstream,
- fix VM_FOREIGN users after c/s 878:eba6fe6d8d53 (bnc#760974).
- gntdev: fix multi-page slot allocation (bnc#760974).
- mm: pmd_read_atomic: fix 32bit PAE pmd walk vs pmd_populateSMP
- sym53c8xx: Fix NULL pointer dereference in slave_destroy (bnc#767786).
- sky2: fix regression on Yukon Optima (bnc#731537).
• https://bugzilla.novell.com/show_bug.cgi?id=700174
• https://bugzilla.novell.com/show_bug.cgi?id=716996
• https://bugzilla.novell.com/show_bug.cgi?id=731537
• https://bugzilla.novell.com/show_bug.cgi?id=731720
• https://bugzilla.novell.com/show_bug.cgi?id=732006
• https://bugzilla.novell.com/show_bug.cgi?id=735362
• https://bugzilla.novell.com/show_bug.cgi?id=736268
• https://bugzilla.novell.com/show_bug.cgi?id=745929
• https://bugzilla.novell.com/show_bug.cgi?id=747038
• https://bugzilla.novell.com/show_bug.cgi?id=747404
• https://bugzilla.novell.com/show_bug.cgi?id=748463
• https://bugzilla.novell.com/show_bug.cgi?id=748859
• https://bugzilla.novell.com/show_bug.cgi?id=752460
• https://bugzilla.novell.com/show_bug.cgi?id=754186
• https://bugzilla.novell.com/show_bug.cgi?id=756840
• https://bugzilla.novell.com/show_bug.cgi?id=757783
• https://bugzilla.novell.com/show_bug.cgi?id=757789
• https://bugzilla.novell.com/show_bug.cgi?id=758243
• https://bugzilla.novell.com/show_bug.cgi?id=758260
• https://bugzilla.novell.com/show_bug.cgi?id=758813
• https://bugzilla.novell.com/show_bug.cgi?id=759545
• https://bugzilla.novell.com/show_bug.cgi?id=759554
• https://bugzilla.novell.com/show_bug.cgi?id=760077
• https://bugzilla.novell.com/show_bug.cgi?id=760279
• https://bugzilla.novell.com/show_bug.cgi?id=760860
• https://bugzilla.novell.com/show_bug.cgi?id=760902
• https://bugzilla.novell.com/show_bug.cgi?id=760974
• https://bugzilla.novell.com/show_bug.cgi?id=761681
• https://bugzilla.novell.com/show_bug.cgi?id=762991
• https://bugzilla.novell.com/show_bug.cgi?id=762992
• https://bugzilla.novell.com/show_bug.cgi?id=764864
• https://bugzilla.novell.com/show_bug.cgi?id=765102
• https://bugzilla.novell.com/show_bug.cgi?id=765320
• https://bugzilla.novell.com/show_bug.cgi?id=767786
• http://cve.mitre.org/cgi-bin/cvename.cg ... -2009-4020
• http://cve.mitre.org/cgi-bin/cvename.cg ... -2011-3347
• http://cve.mitre.org/cgi-bin/cvename.cg ... -2012-2119
• http://cve.mitre.org/cgi-bin/cvename.cg ... -2012-2123
• http://cve.mitre.org/cgi-bin/cvename.cg ... -2012-2136
• http://cve.mitre.org/cgi-bin/cvename.cg ... -2012-2373
• http://cve.mitre.org/cgi-bin/cvename.cg ... -2012-2663
